SailNet Community - View Single Post - Tacking in heavy winds
post #2 of Old 05-02-2012
Faster
Re: Tacking in heavy winds
There was another thread recently with the same issue... tacking in a strong breeze with just a headsail requires a lot of speed, in other words if you're pinching to keep the heel off your boatspeed is likely down.. turning into the wind slows you further and the center of effort is so far foward that once you lose way you simply get blown around.
Having the main up (properly reefed) usually makes that go better, the C of E is more aft and the weather helm contribution of the main helps drive the boat through the eye of the wind.
In extreme cases where you're headsail only, you may need to jibe through 270 degrees and come up to your new 'tack'.. but again you have to do this with speed soas to maintain steerage.
As was mentioned in the other thread, some boats (and rig designs) can handle headsail only better than others.. practice will soon tell you which you've got.
Faster is online now
