SailNet Community - View Single Post - Stripping the bottom paint
post #20 of Old 05-03-2012
tommays
tommays's Avatar
Re: Stripping the bottom paint
At some point in time the PO did a really good barrier coat job which i saw no point in damaging as the boat has never had blister issues (knock on wood )
SO i used a carbide PULL scraper to get off the 15 some odd layers and it TOOK a long time perhaps 5 FULL days
BUT your in a time VS money deal and saving time would have cost 2K and removed perfect barrier coat
I scraped to barrier coat and did a fast 80 grit scuff and then did MORE barrier coat and followed up with micron extra in the recommended time frame WHICH is pretty much instantly
The topsides and bottom paint TOOK the most hours in a two year refit BUT if i had and indoor work area it would have taken MUCH less time and if i had HEAT even LESS time
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
