SailNet Community - View Single Post - Slow, slow, slow and menu not responding
post #11 of Old 05-03-2012
jackdale
jackdale's Avatar
Re: Here is how to fix your code to speed things up
Originally Posted by cupper3 View Post
Sailnet admins, here is your fix for the slow loading. It is a simple, simple code change.
Current code on line 5151 reads:
"<****** type="text/javascript" src="http://www.bibsonomy.info/icons/icons.php">"
As you may be aware, that website is not running. It also has a history of being a problem with numerous other forums; if your not aware of that, you should be.
Alter it by following the instructions here.
I guess the next question is why the heck you have that many (total of 5229) lines of code on your opening page?
Good catch.
The bloatware is likely the result of a WYSIWYG editor. A real html coder would not have the patience to deal with that.
I learned HTML about 1990 on Notepad. All text based stuff.
jackdale is offline
