SailNet Community - View Single Post - Stainless Steel Bolts
post #7 of Old 05-06-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Stainless Steel Bolts
Originally Posted by sevseasail View Post
I thought 316 was the preferred for the marine use.....
You were right. 316 is a bit weaker than 304 but is more corrosion resistant. This is one of those cases where you have to be careful about info gleaned from the web. I have seen actual tables on the web that showed 316 was stronger but it isn't.
As a VERY rough rule of thumb, constituents in alloys that improve corrosion resistance (chrome, nickle) either don't increase it's strength or actually weaken it. Constituents that strengthen it (carbon) reduce its corrosion resistance.
SloopJonB is offline
