SailNet Community - View Single Post - Stainless Steel Bolts
post #8 of Old 05-06-2012
sevseasail
sevseasail's Avatar
Re: Stainless Steel Bolts
You were right. 316 is a bit weaker than 304 but is more corrosion resistant. This is one of those cases where you have to be careful about info gleaned from the web. I have seen actual tables on the web that showed 316 was stronger but it isn't.
As a VERY rough rule of thumb, constituents in alloys that improve corrosion resistance (chrome, nickle) either don't increase it's strength or actually weaken it. Constituents that strengthen it (carbon) reduce its corrosion resistance.
Thank you for that !!
S/V Chata
1980 Catalina 22
"Common sense is the least common of the senses"
sevseasail is offline
