SailNet Community - View Single Post - Is this SAFE? - Propane tank
post #9 of Old 05-06-2012
dabnis
Re: Is this SAFE? - Propane tank
Originally Posted by SailMonkey View Post
I will do my best not to run into or be run into by anything...
I will always have the tank valve off when not in use (underway, near things that hit boats). So the tank itself being damaged enough to leak would take a pretty serious and accurate hit.. a risk I'm willing to take.
I should mention that all other aspects of the install will be standard. Solenoid valve, sniffer in bilge, panel at the stove, single gas line through the boat to stove...
Kind of sounds like you had your mind made up before asking for opinions
Paul T
dabnis is offline
