SailNet Community - View Single Post - Seatalk help needed badly
post #8 of Old 05-06-2012
Classic30
Once known as Hartley18
Classic30's Avatar
Dock
Re: Seatalk help needed badly
Originally Posted by old-sailer View Post
Can I pick your collective brains??
I have an elderly Autohelm depth unit (now owned by Raymarine) AND a Raymarine speed log, they talk via Seatalk cable. No problem there.
I purchased a Raymarine ST40 wind, a Seatalk junction box and a 15 ft cable to connect them all together, BUT the older units will not talk to the new ST40 wind.
O-S, just so you don't think you're asking a stupid question, if you've got the ST40 Depth working with your Autohelm, I can't see any reason why the new unit shouldn't work too - although Raymarine have been known to come up with you-beaut firmware revisions and not test for backwards compatibility.
Assuming you've followed the Manual and all your Seatalk connections are tight: If you change the backlight level on the Wind unit, does it change on the Depth display also - and vice-versa??
(Might seem like an obscure thing to ask, but that's how you check that data is being passed between Raymarine instruments)
Classic30 is offline
