SailNet Community - View Single Post - burping on MD7A
Thread: burping on MD7A
post #4 of Old 05-07-2012
cas206
Re: burping on MD7A
My newly acquired boat came with a MD7A that is not pumping water. I plan to try and flush the system using a trick I saw in an old magazine. The article described attaching a bilge pump to the water intake hose and sticking in a bucket. The water output was routed via a hose back to the bucket. This way a cleaning solution of some sort (water and vinegar maybe?) could be continually cycled through. I replaced the water intake ball valve with a safety seacock. So it will should be easy for me to switch off the outside water and redirect water intake from a bucket.
This is, of course, after I check simple things like replacing the impeller. You might try the bilge pump trick to force any air out of your system (assuming this is even an issue).
cas206 is offline
