SailNet Community - View Single Post - Issues with heaving-to
post #8 of Old 05-08-2012
sailingfool
ASA and PSIA Instructor
Re: Issues with heaving-to
Originally Posted by peterchech View Post
.... I hove-to several times for practice, and after initially heeling way over the boat balanced into that almost magically calm position of being hove-to. No matter what I did, playing with the mainsheet, traveller, and rudder, I could not get the boat to heave-to in any direction other than almost exactly beam-on to the swells. ...
You should be able to adjust the hove-to angle by trimming the main.
when going into hove-to, you should fully release the main (what you do with the traveller then does not matter...). When the boat has hove-to, if you slightly trim the main, the boat should turn closer to the wind. If you trim the main too much, the main will cause the boat to tack.
sailingfool is offline
