SailNet Community - View Single Post - Docking stern in, strong crosswind
post #3 of Old 05-11-2012
nolatom
Re: Docking stern in, strong crosswind
A
But It kind of matters to me, backing a right-hand prop, whether the crosswind is from stbd or port.
If from port, the stern-walk plus the crosswind will put her into a stbd swing too rapid to allow us to stay parallel to the slip long enough to enter it; if it's from stbd though, better chance to hold your heading as you back up, since the turning forces of wind on the bow, and prop-walk, tend to cancel each other out.
But sometimes I just can't get it done without using the outer piling as a pivot point--get the lee quarter partly into the slip, grab the (eventual) leeward bow line from the soon-to-be lee bow outer piling, cleat it to the lee quarter, and back against it as a spring line to pry the bow upwind using the (fendered or rubrailed) outer piling as the fulcrum. Once bow gets parallel to the slip then ease the line some as you move astern and get in.
nolatom is offline
