SailNet Community - View Single Post - Docking stern in, strong crosswind
post #14 of Old 05-12-2012
SVAuspicious
Mermaid Hunter
SVAuspicious's Avatar
Re: Docking stern in, strong crosswind
I have to do this very often.
Without warping in the approach is more dependent on propwalk than anything. That said you will be blowing down. There is no time to line up and back in. You have to align the boat on the fly, balancing the dynamics of windage and drift with rotation. Frankly I usually work to get the stern of the boat and the back ten feet or so stuffed in and then rotate from there with bursts of forward and after thrust, prop walk, and rudder. I can almost always get the boat centered in the slip that way without warps although sometimes rotating on a piling.
Warps make it easier but single-handed warps aren't generally going to happen unless you have everything set up ahead of time. Even then it can be rough.
SVAuspicious is offline
