SailNet Community - View Single Post - What went wrong while sailing downwind?
post #8 of Old 05-12-2012
sea_hunter
Senior Cruiser
sea_hunter's Avatar
Re: What went wrong while sailing downwind?
Downwind sucks pretty much most of the time if it starts to blow and you're in a small shallow draft boat. Adjusting the vang(s) or lifting to let some air blow off before you make the tack works, but can be a little unnerving. In a pinch especially if you don't have reef points on the main is to sail directly downwind and furl the foresail, then apply your tack, making sure your lines are clear and the boom can swing. EG loosen or release the vang(s) and clear your track. Keeping in mind sail adjustments should be done when the hair on your neck begins to tickle, not when you see your cap and sunglasses blown overboard.
sea_hunter is offline
