SailNet Community - View Single Post - autohelm st50 tridata speed-temp transducer
post #5 of Old 05-13-2012
ltgoshen
First String
Re: autohelm st50 tridata speed-temp transducer
I hooked up the Tri-data this weekend and I'm not sure I know how to make it work? I can set the warning settings. I can set the Meter/feet.
It just keeps blinking 0.00 0.00 and It don’t look like its picking up the depth? Any help on this? : Confused:
How did you know your transducer was bad?? How can I check mine? The depth is flashing 0.00 and the temp is reading 53degreese when its realy 72? How do you get it to check the true depth? Can it be calibrated?
Thanks for your help
ltgoshen is offline
