SailNet Community - View Single Post - Faulty fuel injector pump or?
post #2 of Old 10-24-2006
erps
the pointy end is the bow
erps's Avatar
The fuel filter canister should be full. I would suspect a slight leak on the suction side of the fuel system between the pump and the pickup tube in the tank that is introducing air into the system. If you recently did work on the fuel system just prior to the problem, I'd start there. Problems with plugged an/or leaking fuel filters are far more common than injector pump failures.
Ray
S.V. Nikko
erps is offline
