SailNet Community - View Single Post - Identifying a Yanmar
post #5 of Old 05-15-2012
casey1999
casey1999's Avatar
Re: Identifying a Yanmar
Originally Posted by RichardM View Post
I have a three cylinder Yanmar diesel which has the fresh water intake to cool the internal cooling circuit. Is there a way to precisely identify which Yanmar it is, e.g. 3GM30, 3GMD, 3GM30F, through the engine serial number? The engine is in a 1985 Cal 33 is almost certainly original to the boat.
TIA for any help/suggestions.
RichardM
S/V Raven
Cal 33
There should be a name plate on the engine (in the area where the belts are), might need to wipe the area with rag to find it. The name plate should state model and serial number. There should be a name plate also on the transmission (oposite side from where belts are). 3GMD is a direct sea water cooled 3 cylinder Yanmar. Check the pic, name plate is hard to see but is the green/silver rectangle between the belts, just above the place where a hand crank would go.
casey1999 is offline
