SailNet Community - View Single Post - Milky white hot water
post #12 of Old 05-17-2012
dacap06
Send a message via Yahoo to dacap06
Re: Milky white hot water
Originally Posted by cruisingdream View Post
if you just started using this season and stored the boat with rv antifreeze in the water system you will find it does this and will take a lot of water flushed thru to get it out (30+ gal) smelling it should tell if this is the case, also the fresh water tanks may still have some in them but flow clear when cold. For winter storage drain tanks & blow out lines it will save you this problem in the spring.
Oh, right! Good call. I assumed the OP had flushed his system already. I found it takes a great deal of flushing to push all the Propylene Glycol out of the system. You can tell whether any is left because of the change in taste. It took me 5 fill/empty cycles to get rid of the taste.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
