post #2513 of Old 05-18-2012 Thread Starter
Re: Interesting Sailboats
Originally Posted by Mr W View Post
Hi Paulo,
While we´re talking about Bergström & Ridder designed boats, you might want to check out the Route 66:
ROUTE 66
and the B&R 23:
Torkel Båtar - B&R 23
//MrW
Nice boats but a bit dated especially the Route 66.
Regarding Nordic boats that are one that I love and never posted about, the Landmark 43, a Mark Mills design and a beautiful boat:
http://www.landmarkyachts.com/Custom..._43_202_DP.pdf
http://www.landmarkyachts.com/Custom..._43_202_SP.pdf
Mills says about the boat:
Mills Design Ltd. is very proud of the Landmark 43, our latest high performance IRC Cruiser/Racer. This design builds on our unparalleled experience with winning dual purpose IRC designs both custom and production to offer true performance cruising comfort and outstanding results on the racecourse.
This design reflects not only our devotion to high performance design, but also our aesthetic drive to create dynamic high performance yachts of stunning visual appeal.
The hull has been drawn to offer the highest performance across the widest set of conditions compatible with production yacht weight controls and suitable interior volume for a performance Cruiser/Racer….
The waterline length has been set to extract some benefit from IRC’s treatment of overhangs, particularly aft, without going to the extremes of a custom racing design. This ensures a good balance of performance with positive rating attributes. The other performance factors comprise a fine entry for performance in a chop, a narrow waterline beam for reduced frontal drag, and a stern section with a flat run but not overly beamy sections to provide controllable speed offwind without an undue rise in wetted surface area for consistent pace in lighter conditions.
To achieve our weight targets the hull, deck, and interior construction are foam cored epoxy/E-glass laminates. This makes use of the higher materials properties of an epoxy laminate including greater stiffness and resistance to blistering…
The loads generated by the deep keel and bulb however are best met with an anodized alloy keel grid which offers the stiffest solution to static loadings as well as the best force distribution for unusual dynamic loadings such as a grounding…
The bright interior with 3 double cabins and large galley and nav station trimmed with wood is as comfortable for an extended family cruise as it is for racing around the buoys. The spacious head with access both from the forward cabin and the saloon ensures complete amenity.
Attention has been paid to light and ventilation below with careful hatch and portlight placement. In addition to the main hatch and foredeck hatch there are twin small hatches over the head and forward cabin spaces, and a square hatch in the coachroof centrally over the saloon. In the aft cabins there are opening portlights in the cockpit seat fronts.
Sail handling has been arranged with a shorthanded sailing in mind, with all halyards leading back to the cockpit and features items such as the batten slider system on the main and the roller furling jib which have been included in a manner that has minimal impact on the racing performance of the design while improving the shorthanded utility of the sail plan.
This design represents the next generation of IRC Performance Cruiser Racers, and reflects our commitment to creating beautiful, fast, and reliable performance yachts.
Key Dimensions
LOA 13.10 m
LWL 11.26 m
Beam 3.83 m
Draft 2.80 m
Displ 7650 kg
Sail Area Upwind 109,5 m2
Sail Area Downwind 271,5 m
Some movies:
