SailNet Community - View Single Post - Shower sump pump failure
post #6 of Old 05-20-2012
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: Shower sump pump failure
Originally Posted by sea_hunter View Post
Check the joker valves in the pump body for hair etc. Make sure the fuse isn't blown and then take the sump apart and clean the crap off the electronic float switch. You can try dropping a gallon of vinegar down the drain and let sit a few hours with power to pump off. These new electronic float switches get messed up with conditioner and soft soap. If not, take the switch out and clean the slime off of the cover. I replaced all the electronic switches with the old "float" type because the "sensor" style kept failing. Adding a washer between the switch and the sump tank works for a while but it's not permanent fix.
Further to the foregoing, if the pump runs but still isn't drawing water, there is normally a debris filer between the shower pan and the pump with a removable screw top to allow one to clean the screening. If this was left with water in it over the winter, freeze-expansion may have cracked the filter bowl allowing air into the line and disallowing the pump to draw up water.
FWIW...
svHyLyte is offline
