SailNet Community - View Single Post - Micro cruisers
Thread: Micro cruisers
post #148 of Old 05-20-2012
c_witch
c_witch's Avatar
Send a message via Yahoo to c_witch
Re: Micro cruisers
Originally Posted by bljones View Post
You're late.
Yes the water tank took a bit longer the anticipated to get installed due to cooler temperatures. I am looking at June 2nd now. That may or may not happen as today I set the outboard up on my stand at home and went to fire it up only do discover that the engine fuel disconnect is leaking and has to be replaced. Finding one may be a problem as the engine is an 85 Honda . None the less we are down to the last bit in the restoration and only need to paint the cockpit and install the keel winch and keel pivot bolt as well as run the wiring the the mast for the anchor light and vhf.
c_witch
c_witch is offline
