SailNet Community - View Single Post - Food Suggestions
post #94 of Old 05-21-2012
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Food Suggestions
Originally Posted by JanetGroene View Post
Canned foods for and against:
Pro: Open can(s), remove label, sit cans in a pan in an inch of water, cover and heat. Eat out of the can(s), use clean hot water in the pan for washing up. Quick and easy for single hander. Washed cans make good baking pans for muffins, small cakes and until they rust are good for sorting, saving parts when you're disassembling something. Convenient, no waste, easy to fit into provisioning plan. Fully cooked. Require little fuel and, in a pinch, can be eaten cold.
Con: most are all-around nutritional duds and most contain too much salt. Cans rust and, if wet, lose labels. Use grease pencils to label; coat with goo such as Compound L. Messy. If they have aluminum pull-tops a drop of salt water can break the seal. Most new cans open on one end, which means you cannot remove both ends and stomp to flatten. Bulky to stow when full or empty. Ready-to-eat soups easy but you're carrying a lot of water in space that could be used for food.
We would often take off labels, mark with a permanent marker the contents, the paint with varnish. It was not my idea. I got it from a book somewhere along the way (I think it was Life Afloat, but not sure).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
