SailNet Community - View Single Post - Wire to Rope Halyards
post #6 of Old 05-21-2012
msmith10
Junior member, rest old
msmith10's Avatar
Re: Wire to Rope Halyards
Originally Posted by casey1999 View Post
I understand these mast through bolts should have a compression sleave (so to not compress the mast). Where would these compression sleeve be obtained? Never see them sold.
They don't make them, per se. It's just a length of tubing, preferably heavy-wall stainless, that the bolts go through on the inside of the mast, cut to the proper length, so that the mast walls don't compress when the nuts are tightened down.
The big question is how are you gonna get them on the bolts? I guess you could send a feeder line thru the bolt hole, exit the bottom of the mast, pull the sleeve back up to the hole then carefully feed the bolt through the sleeve. Ain't gonna be easy. I guess if you can remove the masthead and get to them that way, it would simplify the matter.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
