SailNet Community - View Single Post - Replace Diesel Fuel Regularly
post #19 of Old 05-21-2012
gordofloats
gordofloats's Avatar
Re: Replace Diesel Fuel Regularly
Originally Posted by Stu Jackson View Post
All of those screens should be removed.
Absolutely! Great advice!
I was pulling my hair out trying to solve my fuel line issues - new primary/secondary filters, manually cleaning hoses and injectors, my Yanmar 3GMF kept quitting in rough weather. Finally, after getting a tip here (it might have been from you, Stu) I checked the intake hose - sure enough, the little screen at the end was clogged with goop and any time rough water stirred up more gunk it stopped up completely. Out with the screen! Tried to get a fuel polish - not a single mechanic in Toronto would touch it. So I got a plastic bin big enough to hold my fuel, took out my oil-change pump and attached a spare secondary-fuel-filter-element and pumped the whole tank into the bin - not a terribly fun job. Removed about 1/2 litre of water as well as the ooze that grows at the interface between diesel and water. Cleaned the inside of the tank with a rag-on-a-wire and filtered the diesel back into the tank. I was completely soaked and stank for a week, but since then I've kept the tank topped up, added stabilizer every season and I haven't had a drop of water show up in my separator or had fuel issues of any kind. I keep the intake screen and the dried up blob as souvenirs of some dicey engine failures.
Pull your screens! You'll be glad you did.
gordofloats is offline
