SailNet Community - View Single Post - Echo Charger with standby battery bank
post #2 of Old 05-23-2012
Maine Sail
Maine Sail's Avatar
Re: Echo Charger with standby battery bank
Originally Posted by sstuller View Post
Can you use an Echo Charger to charge and maintain a standby battery bank that has the same capacity as the primary bank (100 AH @ 24 volts)? Am using a solar panel for charging which is idle once the primary bank is charged. Thanks. Steve S.
If your other bank is no longer receiving a charge the Echo will also shut down..
______
-Maine Sail / CS-36T
Maine Sail is offline
