SailNet Community - View Single Post - Echo Charger with standby battery bank
post #5 of Old 05-23-2012 Thread Starter
sstuller
Re: Echo Charger with standby battery bank
I'm using a Steca controller that has a float stage. One of the questions I have about the Echo is the statement that it will provide 15 amps to the auxiliary battery bank if the voltage differential is 1.5 volts between the banks. Since the solar panel doesn't come close to that output, is the Echo output limited to the solar panel's output? Thanks.
sstuller is offline
