Old 05-27-2012
CarelessNavigator's Avatar
CarelessNavigator CarelessNavigator is offline
CarelessNavigator is on a distinguished road
Re: Westerbeke - no start post inj. pump rebuild.
Originally Posted by sigmasailor View Post
An easy way to verify the injectors deliver fuel is leave them out of the cylinder with HP line connected. Do keep away from the jet of fuel; this will harm you when you touch it.
Not to criticize, but that is a horrible idea.
If you bend the injector lines enough to do what you are saying you risk kinking the injector lines creating reduction in pressure and volume which could lead to reduced participation or an outright misfire, improper atomization of fuel causing the injector to clog then washing the cylinder down.
Bending injector lines is bad kids UH MMMMKay
