SailNet Community - View Single Post - Westerbeke - no start post inj. pump rebuild.
post #7 of Old 05-27-2012
sigmasailor
sigmasailor's Avatar
Re: Westerbeke - no start post inj. pump rebuild.
Originally Posted by CarelessNavigator View Post
Not to criticize, but that is a horrible idea.
If you bend the injector lines enough to do what you are saying you risk kinking the injector lines creating reduction in pressure and volume which could lead to reduced participation or an outright misfire, improper atomization of fuel causing the injector to clog then washing the cylinder down.
Bending injector lines is bad kids UH MMMMKay
Normally there is some clever way to connect everything without bending fuel lines. It's quick and easy and will narrow down on the problem. I should have pointed out not to bend the fuel lines.
sigmasailor is offline
