Old 10-28-2006
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
Joe...is the water coming through the gasket area or from around the base of the hatch itself? You might try simply gluing up some new rubber stipping to the lid and perhaps the extra thickness will allow you to snug down the handles tighter and cure the problem. Try auto stores for the rubber stripping like they use on car doors.
I don't understand how the hatch is mounted to your hull. I've never seen a production hatch that can't be removed. Worst case...you can cut it out and fit a slightly larger new hatch in its' place.
