SailNet Community - View Single Post - Engine Alarm Buzzer
Old 10-28-2006
hellosailor's Avatar
hellosailor hellosailor is offline
Duke, before you assume the piezo is bad? Use a multimeter or test light to check on it. It is also possible (I think) that if one diode shorted, instead of failing open, it would simply ground the other signals and prevent the piezo from sounding. (Which is why three separate circuits could be good, even though three times more parts could just give you three times more stuff to fail.)
