SailNet Community - View Single Post - swing keel problem
post #20 of Old 06-02-2012
JUST MESSIN WITH IT
Re: swing keel problem
Originally Posted by windyway View Post
Attached is a picture of my keel measurements before my repairs, then during the repairs a steel bottom was installed. The cable fitting came off last weekend & I had to go thru the effort of keel removal again! What a PITA ! Where the keel strikes the forward part of the keel slot on the hull I mounted a 3/8 thick piece of nylon as the wood I used last time got gouged. The cable was otherwise in perfect shape.
Hey Thanks for the pictures guys, a couple of questions.
Is the 47 inches the finished length or the before repair length.
What would be the finished length
Assuming a circlular section at the top of the keel with circumference of about 15inches with the keel pin in the center is 1 3/4 inches thick, does the keel narrow along its length? Just thinking that top section of the keel must fit pretty snug to reduce the movement during use, but the rest needs to move in and out freeley.
Just how much side to side movement ( wiggle room ) do you have on the keel. To make it snug fit could i cut a thin 15 inch diameter nylon washer.
Thanks for advising guys , you been very helpful
JUST MESSIN WITH IT is offline
