SailNet Community - View Single Post - Garhauer, Harken, Lewmar & Schaefer
post #15 of Old 10-30-2006
sailingdog
Ratchet blocks act to give you more control over a line and help reduce the load on your hands, by resisting the turning force of the asym sheets. I use one for the boom brake setup on my boat. Depending on the size of the asym and the winches used for it, you probably don't need a ratchet block. Generally, they're only used on lines that are handled manually, not ones that have a mechanical advantage device.
sailingdog is offline
