SailNet Community - View Single Post - How Far Do You Heel...?
post #8 of Old 06-04-2012
chef2sail
chef2sail's Avatar
Re: How Far Do You Heel...?
C2S - Having been a boat that rounded up from a broad reach (under white sails) I can attest that weather helm can be found on other points of sail.jackdale
Weatherhelm usually only comes into play when close hauled as an indicator.-chef2sail
Note the word usually. I outlined in in bold so you would see it this time as you must have read what I said too quickly and felt the need to correct me.. Of course you feel weatherhelm on other points of sail.
Too much heel equals too much weather helm-,jackdale
My statement was saying that you should not use whetherhelm to detemine whether your angle of heel is slowing you down. You will usually feel that constant weatherhelm on a close haul. Some boats sail very comfortably with a moderate amount of weatherhelm and it does not slow them down or make them round up. It also depends on wind conditions whether constant or gusty and how the boat is designed. If you sailed my C&C 35 upright with no weatherhelm....you will not go as fast. Every boat has its tipping point which depends on design...sail used etc. Its like reefing. There are many variable factors. Heel angle is similar as pointed out by stumble.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
