Old 06-04-2012
SchockT's Avatar
SchockT SchockT is online now
SchockT is on a distinguished road
Re: Farr Ims 40.7 and possibility of putting aft swept back wire?
Originally Posted by thenzsea View Post
Thank you and 3 questions?
1. Jumpers? You mean wires like stays at the top?
2. Even if I put Permanent backstay, wouldn't it be helpful for making rig
stronger?
3. Openning up the top of the main means that when I pull the backstay
it just help to twist (=open) the main. isn't it related to move the
draft back of sail that help for beating?
The masthead backstay on your rig primarily serves as a mast bending tool. Bending the mast flattens the mainsail. Bending the mast will also twist off the top of the sail if you don't compensate with more sheet tension. The permanent backstay will prevent your mast from falling down in the absence of the runners, but it will not make it stronger. In strong wind a serious mistake on the running backstays could still break your mast!
The running backstays control your forestay tension, and your check stays limit the amount the mast bends, and prevents it from "pumping" through waves.
