SailNet Community - View Single Post - Head holding tank vent line - 1981 E37 Plan 'B'
post #3 of Old 06-04-2012
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Re: Head holding tank vent line - 1981 E37 Plan 'B'
If the vent line actually runs down and then up it essentially forms a "trap". Any moisture inside will pool at the lowest point and prevent air from getting through, hence the stink. I would re-route the line so that it has no low points. I would also install a second vent in the tank. A single vent will only act to equalize the pressure between the tank and the atmosphere, with little or no circulation. This results the tank becoming anaerobic and stinking. Having two vent lines, with their exterior fittings located as far apart as practical (for a slight pressure differential), will allow for exchange between the tank and atmosphere, and help to keep the tank aerobic (and MUCH less stinky).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
