SailNet Community - View Single Post - Do you personally get seasick?
post #7 of Old 06-05-2012
christyleigh
christyleigh's Avatar
Re: Do you personally get seasick?
I'm OK as long as I can see what's going on and let my brain understand the motion. Wave bashing or long rollers for hours no problem - on deck. When I had to go into the bowels of a previous boat to clean a clogged raw water strainer with no outside reference just in a light chop I was nauseous for the rest of the day. When I had to change the clogged fuel filter daily after failures bringing home the boat from Annapolis I was OK because it was under the pilothouse sole and I could work/concentrate a little, look out and around a little to re-orient my brain, and over again until done - no problem. I can't read in a car or bus - nausea. Merry Go Rounds used to make me nauseous. Rolly moorings or anchorages are OK, even for sleeping, but I don't try to read. On a cruise when at anchor setting up the next day's GPS points I have to take breaks to get my head straight. So.... I have some form of Motion Sickness but 99.9% of the time I can control it
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
