SailNet Community - View Single Post - swing keel problem
post #23 of Old 06-06-2012
makenmend
Re: swing keel problem
Found cable to CB had parted, small # of blister's ground our & filled.Grafite /epoxy applied, new cable + hardware obtained, so final steps getting close. refit CB/cable,the cable attachment was about to fail, so it has to be repaired,add extra gudgeon to rudder,trailer still to do as well.
windyway to do your roller mod for theCB cable did you cut off the top of the CB trunk or build it up ??
MM
makenmend is offline
