SailNet Community - View Single Post - swing keel problem
post #25 of Old 06-06-2012
windyway
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Re: swing keel problem
Originally Posted by makenmend View Post
Found cable to CB had parted, small # of blister's ground our & filled.Grafite /epoxy applied, new cable + hardware obtained, so final steps getting close. refit CB/cable,the cable attachment was about to fail, so it has to be repaired,add extra gudgeon to rudder,trailer still to do as well.
windyway to do your roller mod for theCB cable did you cut off the top of the CB trunk or build it up ??
MM
If you look up into the CB slot in the shoal keel you'll see a recessed area that the cable comes out of, the pulley bracket fits into this upper recessed area.
windyway is offline
