SailNet Community - View Single Post - Is a 44' too much?
post #9 of Old 06-07-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Is a 44' too much?
Originally Posted by JustinB View Post
Hmm 30k plus? That's quite a bit. I bought the new to me sails for my Cat for $500.
I did sail solo to the Azores but there were 2 other boats in the group so if I messed up it would not be a disaster. I am not very knowledgeable about sailing, I just kind of winged it. I would want some proper training before I get a bigger boat. Though my lil sailboat seems the better option since $$ is relatively important.
A Mercer is about 4X the size of a Cat 27 (27K Lbs. vs 7K). The cost of boat bits goes up pretty well exponentially with size. The Mercer has 885' of sail vs 346' on the Cat and those sails are much heavier material, reinforcing etc.
I think your sailing experience is adequate - I daresay most of us here haven't crossed the Atlantic under sail, certainly not in a toy boat like a Cat 27.
I'd be more focused on the cost and work to fix that big Mercer. I'm currently doing a Columbia 43 - very similar size boat from the same designer. It's not my first restoration and it's a BIG job. I didn't have to replace the engine or patch the hull either. I did have to completely rebuild the rig though.
If you found used gear, rebuilt engine etc. and did much of the work yourself, you MIGHT do it for $30K but I personally doubt it could be done that cheap. If you intend to basically write cheques to have the work done, it will go over $50K easily.
One big item would be the rig - can you just replace the tube and reuse all the other bits? Or does it need a complete new rig? BIG difference in cost between those two possibilities. Just a boom for that boat would be 4 figure$.
SloopJonB is online now
