SailNet Community - View Single Post - Master switch doesn't work, thinking of rewiring the boat
post #6 of Old 06-08-2012
blobaugh
blobaugh's Avatar
Re: Master switch doesn't work, thinking of rewiring the boat
Rewiring the boat is a chore and a half. Do what windyway said and check the fuses. Stick your head behind the panel (or pull it off) and see if there is corrosion or loose wires. The electrical systems in these boats are very simple and not much can go wrong. I would vote for bad fuse, switch, or loose wire
blobaugh is offline
