SailNet Community - View Single Post - laminate cutting
post #3 of Old 11-01-2006
Ronbye
Ronbye's Avatar
I am assuming that you are replacing the rotten plywood substrate. If so then you can apply the laminate then cut out the openings with a laminate trimmer, which you should be able to rent. Be careful though as like any high speed tool, it takes a bit of getting used to. I would suggest that you practice on a couple of scrap pieces first to get the feel of working with such a device. It should work out fine.
Ronbye is offline
