SailNet Community - View Single Post - Roller reefing
Thread: Roller reefing
post #5 of Old 06-10-2012 Thread Starter
mgb69
Roller reefing
Thx for quick replies.
My first thought was that the furling line was getting fouled (I had wrapped up way too much the first time). Stripped out a bunch - but maybe I need to keep more tension on the line as I reel out the sail. Given the drum spins easily by hand I think this is the most likely culprit.
Line is running clear to a block on the bow pulpit - so that shouldn't be the issue.
Boat is on salt water, definitely no servicing in last few yrs. Just bought some marine lube - I'll see if that helps.
I'll be sure to sort it out rather than just going with more force! Given the small line I couldn't see how it would have been designed to withstand winching.
Thx again
Mark
mgb69 is offline
