SailNet Community - View Single Post - Fishfinder vs depth sensor
post #21 of Old 06-13-2012 Thread Starter
Romario
Re: Fishfinder vs depth sensor
Originally Posted by travlineasy View Post
Because the pulse from the transducer is such a short duration, the power consumption is extremely low. If it were a constant 1,000-watts you're battery would be dead in a matter of hours. With this system the battery will last for weeks without going dead.
Good Luck,
Gary
Thanks for the update, that's what I figured, those are peak watts, whereas the RMS watts are much lower (Wikipedia says you should be divide by 8 to get the actual power consumption).
Romario is offline
