SailNet Community - View Single Post - Difference between alcohol & kerosene stove?
post #15 of Old 06-13-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Difference between alcohol & kerosene stove?
The biggest problem you would have with running diesel through a kerosene stove is the smell and the fumes. With the burners set for kero they would go apeshite if you loaded them up with diesel and the soot would probably drive you from the boat.
That is not to say that a properly configured diesel stove is smelly or dirty.
I'd be interested to know where you intend sailing ? Reason for asking is twofold. First, if you intend heading for warmer climes then for mine a diesel or kero stove would be damned uncomfortable to live with , even LPG heats a cabin up in summer and secondly why do you think LPG is difficult to obtain outside of the USA ? In our part of the world LPG is probably the most common fuel for on board use and in SE Asia and the Oceanian Islands it is replacing or indeed has replaced most other portable fuel sources and in ten years time it will be even more firmly entrenched than now.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
