Old 11-02-2006
SailorMitch's Avatar
SailorMitch SailorMitch is offline
Senior Moment
SailorMitch will become famous soon enough
I partially agree with Gene T -- why remove the two coats of Trinidad assuming it is in sound shape? I'd repaint, but using an ablative so that you won't get a build up of layers of paint in the future.
But to answer your question if you really, really want to remove that paint: yes, I have used chemicals twice and they work very well. Depending on the brand you use, apply it, wait the stated time for it to work, test a patch to see if it comes off easily, if not wait a bit longer. I use plastic scrapers from Home Despot.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
