SailNet Community - View Single Post - Tips and tricks for getting rid of crab/lobster floats
post #5 of Old 06-19-2012
Stumble
Re: Tips and tricks for getting rid of crab/lobster floats
Brent,
Line cutters work, right up untill they don't. I had to replace the shaft of my last boat due to a line wrapping the shaft and torquing it out of true. Sadly the line cutter couldn't make it through the wire leader in the line.
I generally assume I am going to have to cut away crab traps when they get hooked. Sometimes you get lucky, but if the engine is running they almost always wrap, and if you are sailing they tend to slide off without getting a bite on anything.
Greg
Stumble is offline
