SailNet Community - View Single Post - air conditioning
post #2 of Old 11-03-2006
sailingdog
There are other problems besides the lower stability, as it will shift the COG up and reduce overally stability of the boat, as it heels, the 100 lbs. of the AC unit essentially cancel out a part of the righting moment generated by your keel.
The biggest of these is the fact that the AC unit will be a weak point in heavy seas or in the case of a knockdown. If the AC unit shifts, breaks or falls out, it will allow a lot of water to come into the cabin, and if you're on a ballasted monohull, downflooding is a strong possibility.
Also, the unit is probably not designed to resist the corrosive effects of a marine environment. There is a good reason that WM sells carry on units, rather than permanent installations. Most people do not have a sufficiently large battery bank to support running an AC unit, except under shore power—so why carry the weight when you're sailing??
sailingdog is offline
