SailNet Community - View Single Post - Tips and tricks for getting rid of crab/lobster floats
post #9 of Old 06-19-2012 Thread Starter
MastUndSchotbruch
Re: Tips and tricks for getting rid of crab/lobster floats
Put a line cutter on your prop shaft and forget about them. I have a blade , bolted to the front of my aperture, running down at a 45 degree angle, just touching the prop hub. Any line trying to wrap around this blade is instantly sliced.
Cutting the odd crab pot line is just a part of cruising. If they want to save their pots, they should keep them out of main channels. We cruisers should not have to bear the costs of such foolishness (bent prop shafts, wrecked trannys and bell housings, etc.).
I HAVE a line cutter, in the space between the strut and the prop.
Are you saying I should move the line cutter all the way back until it touches the prop?
Two weeks ago a line from a crab pot got in-between the line cutter and the prop. I had to do a quick haul-out (at the cost of several hundred dollars) and it may have bent the shaft slightly.
MastUndSchotbruch is offline
