SailNet Community - View Single Post - Furler hard to unfurl/furl on genoa
post #4 of Old 06-19-2012
jackdale
jackdale's Avatar
Re: Furler hard to unfurl/furl on genoa
I have jammed loose spin halyards in the swivel. They have to be bar hard to prevent that. But they do not turn once jammed. I would suspect bearings. Make sure you flush out the lower ones regularly.
Are you keeping slight tension on the furling line as you unfurl the sail? You will get a rats nest if you just let it go, and it will jam.
jackdale is offline
