SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #187 of Old 06-20-2012
casey1999
casey1999's Avatar
Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by a_deveau@ns.sympatico.ca View Post
I have one question, I'm esealing around my chain plates. I want to pour thinkened epoxy around the chain plate to seal the balsa and ensure no water get in. I also want to leave a uniform gap between the hardened epoxy and the chain plate so that I can seal it. Could I install the chain plate wrap the chain plate with butyl tape then pour the thickened epoxy around the butyl tape so that once it hardens the butyl tape will be sealed against the chainplate?
I'll let someone else answer, but you might want to change your name so you don't get spammed.
casey1999 is offline
