SailNet Community - View Single Post - Helms25 Window Gaskets
post #4 of Old 06-20-2012
Wayne25
Wayne25's Avatar
Re: Helms25 Window Gaskets
It would be my opinion that fixing your existing ports is the easiest and cheapest way to get the job done. plus its original if that matters to you. It doesn't cost a lot to get safety glass made to replace the plexiglass.
If I remember correctly, the removal steps were:
1. -Unscrew the aluminum channel that holds the window curtains.
2. - Unscrew the interior aluminum frame that pulls the exterior frame tight to the hull.
3. - Carefully remove the aluminum frame that holds the plexiglass. Hopefully the bedding compound loosens up easily.
Good luck with the project.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
