SailNet Community - View Single Post - Building a head tank
Old 11-04-2006
roline's Avatar
roline roline is offline
Cal 9.2 SilverSwan
roline is on a distinguished road
I do not recommend fiberglassing in the holding tank. The Hunter 28.5 has the holding tank glassed in under the rear area and the one in our club had a nasty odor that could be detected from the dock when you walked by. My Cal 9.2 had a bladder holding tank and I do not recomment that method, same issue odor. I could not find a tank that I liked so I ended up custom fabricating one from 12 layers of glass and epoxy. It is 3/8 to 1/2" thick and is removable if needed. I would have prefered HDPE. Use the expensive white solid reinforced vinyl hose with short runs to the tank. My tank is behind the head so when flushing, the transfer hose can be flushed with a few extra pumps to be sure it will only have flush water sitting in it.
